Error code 077-131 on Xerox 7232
  • yomba
    • Jul 2012
    • 37
    I have this persistence error code 077-131 on xerox 7232. i have re-seat the cables on the print head but it keeps coming back every few days. ANY SUGGESTIONS ?
  • selig67
    • May 2008
    • 158
    Re: Error code 077-131 on Xerox 7232
    edoc refered to fuser or chute. here are some searchlite enteries....
    Replace Cover Chute PL2.7 item 5.
    Replace vertical door PL 2.7 item 2 is not spared use PL 2.7 item 1 door assembly .
    CHANGE FUSER MODULE
    After replacing the Fuser and checking the Duplex Sensor and the Solenoid at the exit, I made some two sided copy With the Duplex Assembly unclip on the side to see the entrance of the Left Hand Upper Cover and saw the sheet Touch the unglued Mylar.
    Put some glue on the Mylar or replace it.
