Set IP in xerox 5225
  • shaahin
    • Jun 2017
    • 26
    Hi all
    I have a problem with xerox 5225.
    connectivity and network setup not appear in xerox 5225 tools.
    so i can't set IP address for print or scan.
    how can i fix it.
  • rockdude
    • Feb 2011
    • 257
    Re: Set IP in xerox 5225
    First are you logging in as Admin? Pass: 11111
    Should say "System Administrator" upper right corner of display.
    Then go to press Machine Status, then tools, then Network Productivity Setup.
    Then change IP V4 to DHCP. Reboot machine, check IP with configuation page.
    The go back in the same way and set ip to correct address and set to static.
    • shaahin
      • Jun 2017
      • 26
      thanks for reply
      but in tools ,the machine hasn't any network option to change.
      and isn't any notification about network in configuration sheet.
        Originally posted by shaahin
        thanks for reply
        does the machine have an IP set in it already? if so can you hook a laptop up with crossover cable and web into it?
        • shaahin
          • Jun 2017
          • 26
          not yet . used beafore coppier only.
          and i can't connect with laptop.
          • shinchan
            • May 2011
            • 197
            Hi all
            how can i fix it.
            try unplug and plug the network card again.
            if it doesn't work, swap network card from a healthy machine.
