116-317
  • jdshaw333
    • Jun 2025
    [Error Code] 116-317
    Replaced memory after reseating and popo. Still boots directly into the 116-317 code. Also can not access diagnostics/service mode. Please Help!
    Re: 116-317
    what machine are you talking about ... just an error code isn't very much help.
    • prismtech
      • May 2014
      • 199
      Re: 116-317
      I love these posts.
      Sent from my SM-G903W using Tapatalk
      • jdshaw333
        Re: 116-317
        Terribly sorry super late night it is a Xerox Workcentre 7232
        • adriansto
          • 2383
          Re: 116-317
          Check voltages on ESS pwb, then dimm memories.
          If the machine have Postscript dimm it can be a cause of the error. Remove Postscript and check again.
          Also ROM dimm can be fault.
          • rockdude
            • Feb 2011
            • 257
            Re: 116-317
            In my case it turned out to be the Power Supply (I got my error code immediately at startup).
            Part Number 105E16382 (120V)
            I have also heard as "adriansto" said that the Postscript DIMM can be the problem.
            Good Luck
            • jdshaw333
              Re: 116-317
              The machine had Postscript Dimm but when removed it will not boot at all. Is the ROM Dimm the one located under the hard drive?
              • jdshaw333
                Re: 116-317
                Originally posted by prismtech
                I love these posts.
                to be or not to be a prick............
                • prismtech
                  • May 2014
                  • 199
                  Re: 116-317
                  To be.
                  Call 1-800-ASK-XEROX and get a real tech out.
