X4110 - Fuser banging noise when disarming
+ More Options
Posts
  • paul_gmb
    • May 2014
    • 33
    Hey there,
    We have a metal noise when the fuser disarmes ( when the nip lowers the pressure roller ) .
    We have found the nip gear 55T metal gear, to have 2 broken teeth. We replaced the gear but noise is still there.
    Even with the fuser out, when we manually disarm the fuser, the noise is still there. So it's clearly a shock from that.
    Is this normal or is there something else we could check.
  • Milo Wilson
    • 499
    Re: X4110 - Fuser banging noise when disarming
    I've seen this when there is a toner builup on the pressure roll cleaning blade. It is probably caked with toner.
    • paul_gmb
      • May 2014
      • 33
      Hey there. Thanks for the quick reply. We don,t have a cleaning blade. The eureka recommends taking it off. Most fuses are shipped without one now.
