Xerox 7675 "UI/NC Cable failure
  • shango215
    • Jul 2025
    [Error Code] Xerox 7675 "UI/NC Cable failure
    Hello All, Looked at all previous info on this situation and it didn't seem like a consensus had been formed yet. Mine is a xerox 7675 which says
    Reset the machine
    UI/NC interface Cable failure has occurred.
    The Machine may have been powered
    on to quickly.
    Power OFF the machine
    WAIT 2 MINUTES
    Power ON the Machine.
    This has not worked and I was hoping to get Clarification before proceeding to try Everything previously posted. The machine did sit at least 6mos before this attempted activation if that somehow makes a difference as one previous reply inquired about sit time. Any insight would be greatly appreciated. thanks
  • adriansto
    • 2387
    Re: Xerox 7675 "UI/NC Cable failure
    Remove the usb cable and watch what message is poped by machine.
    If the message is changed then you have a bad usb cable - it is not an ordinary one.
    If the message is same then you need to check if net controller is booting ok.
    • selig67
      • May 2008
      • 158
      run an Altboot through your PWS
