Bizhub C6500
+ More Options
Posts
  • PoonKing5000
    • Jun 2008
    • 111
    Bizhub C6500
    Hi, i usually work on Canon's but i was doing a PM on a Bizhub C6500. Following the sercice manual the PM went pretty well no problems except after i had finished i now am getting a ghost image.
    When i run multiple copies i get a shadow of the first page on the second page. I have checked all transfer rollers and the transfer belt and cleaning blade, everything seems to be working fine. The ghost image is just a light grey shadow, not streaky.
    It also only happens when i run color prints. If i just run black copies they look great.
    Any help would be greatly appreciated. Thanks.
  • fernan
    • Jan 2008
    • 61
    try to clean also the lamps under the developing units when you remove the drums you will see the lamps just clean it,
    when you done the PM of the machine have you done image adjust (TCR) for all colors?
    • PoonKing5000
      • Jun 2008
      • 111
      Thanks, Ill check the lamps.
      I did run the drum initialization for all drums. I also ran some other service adjustments, no sure if that was one, sounds familiar though... Ill try that.
      Anything else i could check?
      • redhotrob
        • 69
        Did you remove the red screws, front and back, from the drum units?
        • PoonKing5000
          • Jun 2008
          • 111
          No i did not. should i have?
          • redhotrob
            • 69
            Yes, they are shipping screws that keep the cleaning blade off the drum.
            • PoonKing5000
              • Jun 2008
              • 111
              Well that would probably explain a lot. but why would it not do it on when i run Black copies?
              • random
                eventually it would
                • redhotrob
                  • 69
                  One time in a rush pm job, I did the same thing. Ended up taking longer to find the problem then if I had taken my time to do the pm properly. Those things happen when the customer rushes you and stands over watching and waiting.
                  • ni311
                    • May 2008
                    • 658
                    You should have any problems with PM on C6500 as long as you follow all the steps in the exact order from the service manual in the adjustment section. And remove the red screws
                    Konica Minolta Error Codes - Explanations and Solutions
                    • PoonKing5000
                      • Jun 2008
                      • 111
                      Yeah this was the first Bizhub i have worked on and the PM went really easy following the manual(Just took a few hours). I went back over the service manual and i didnt see it mention anything about any red screws though. I'm going to go back to the machine first thing Monday morning so i will take them out then. Thanks for all your help.
                      • PoonKing5000
                        • Jun 2008
                        • 111
                        Problem was fixed by removing those screws... Thanks Again
