C60 - 12x18 discoloration
  • MHeon71
    • Oct 2008
    • 489
    I have 1 C60, where it the color is discolored for the last inch on 12x18 trail edge. It is an intermittent issue, where it does not happen on every set of prints, but it seems if it happens for one, it will happen to all in a set. Does not matter of the color used, it appears to be all colors. Latest sample was more of a burgandy color and the trail edge came out pinkish.
    I have removed the finisher to eliminate that from the equation. I also stopped the print and the image looked fine on the belt. It seems to be worse for certain papers.
    Paper with the most issues is Mohawk Synthetic Performance Paper (Polyester). 12x18-8mil-80M-White 260gsm. I have it setup as Coated 3 paper.
    Thanks,
    Mark
  • adriansto
    • 2387
    Re: C60 - 12x18 discoloration
    If the image looks ok on transfer belt then your problem is 2nd BTR mechanism or even the roll itself
