Duplex Registrtion
  • CRISTIAN MULLER
    • Feb 2013
    • 145
    Duplex Registrtion
    Hello guys, I'm having a trouble to make the duplex side Match the front side of a A3 document, I create 1 document with the same page size, same image (Retangular) and came out with the duplex side slightly up and the machine creates e 5 mm margin that do not have in the file.
    How to make full bleed printings on those machines?
    How to make duplex registration adjusts?
    I have full access at service mode.
    Re: Duplex Registrtion
    duplex registration is covered in the manual
    what xerox machine are you talking about .
    • rockdude
      • Feb 2011
      • 257
      I don't know of any Xerox machines that do "Full Bleed" (edge to edge).
      Some Xerox machines will do 12x18 which you can then cut to A3 (11x17) to give "Full Bleed" for Tabloid prints.
