Hello friends
i have a xerox machine WC 5645 its OK for 1-sided copying when using glass only but when using ADF and making 2-sided copies, the machine jams between the inverter and the duplex module.
When making 2-2sided copies, the paper passes through the inverter but instead of proceeding to the duplex/ 2-sided module,it just drops down under it. In simple terms, the paper is not taken back to the inverter by the inverter solenoid.
For 1-sided from the ADF, the paper tends to go to duplex module and stacks there.
Anyone having an idea on this fault, help me.
Regards
sema
Regards
sema
