Xerox Work Center 3655
  • kmtech
    • Sep 2008
    • 125
    I picked this 3655< once the main switch is turned on it just keeps cycling on and then off. has anyone had this problem?
    Thanks in advance
    Bill
  • Flash
    • 378
    Re: Xerox Work Center 3655
    Try reloading firmware or replacing the hard drive.
    • kmtech
      • Sep 2008
      • 125
      Thanks for the suggestions, I will try them and let you all know what it was
      Bill
      • kmtech
        • Sep 2008
        • 125
        Bill
        I tried to log in but the way its cycling i cant. power on the interrupt button blinks and it turns off and back on again.
        any suggestions..
        • Samwise
          You most likely will have to try doing the altboot procedure, if that doesn't work, then the hdd is unrecoverable, see GP9 in the edoc.
          • rockdude
            • Feb 2011
            • 257
            You can disconnect the hard drive and see if it boots up normally then.
