Xerox 58xx without HDD and SD card
+ More Options
Posts
  • hamedzoro
    • Apr 2015
    • 28
    Hi everyone
    please, I need guidelines to how make the machine 58xx ready with new HDD and SD card ? , and what about the data in the SD card did it the NVM values or what about it ?
    Thanks in advance
    hope someone give me a solution
  • shaahin
    • Jun 2017
    • 26
    Re: Xerox 58xx without HDD and SD card
    Hi
    when you change the hdd , you must install software again with flash memory.
    make a folder AltBoot on flash root then put 58xx software in this folder,
    power off machine put the flash memory in usb slot in the rear of the machin then
    turn the machine on.
    • wtroll
      • May 2008
      • 85
      Hello,
      if you want to retain the original meter counts do not replace hdd & sd at the same time.
      Replace one at time so the machine can automatically syncronize the original meter counts.
      Otherwise this will be at 0.
      However, It may necessary manually syncronize the machine serial number.
