WC5755 Factory Reset
  • spartanfangr
    • Jan 2018
    • 7
    Helping a non-profit that received a WC5755 from a business now closed. Pretty much everything is locked down and cannot get into any setting menus. Is there a way to Factory Reset on this machine so I can get it up and running for them? I'm not entirely familiar with this product so any advice is much appreciated!
  • sureshraidu
    • Oct 2011
    • 28
    Re: WC5755 Factory Reset
    #+login/out simultaneously
    Passwd - 1934
    Diagnostic routine
    Copier routine
    132 initialize
    Select all and confirm one by one.
    Closeout.
    Sent from my F5122 using Tapatalk
    • spartanfangr
      • Jan 2018
      • 7
      Ran through them all and rebooted. Still appears some locks and retains settings. Any thoughts?
      • adriansto
        • 2388
        What version of machine software ?
        • sureshraidu
          • Oct 2011
          • 28
          Post a picture of that screen asking for code.
          You can use it by login as administrator.
          admin - 1111.
          Or disable accounting from machine status- tools.
          • spartanfangr
            • Jan 2018
            • 7
            System Software Version: 061.132.226.28000
            I'm thinking there's something on here preventing me from getting into admin mode.
            • spartanfangr
              • Jan 2018
              • 7
              admin - 1111.
              Thank you. Seems like I can't gain access to the keyboard to allow me to log into admin mode:
              and then when I press the "Keyboard Access" button, this window runs until machine is reset...
              • adriansto
                • 2388
                Probably the machine was connected with authentication server.
                You need to reload same software version into machine.
                • spartanfangr
                  • Jan 2018
                  • 7
                  Will reloading the software reset the authentication settings?
                  • adriansto
                    • 2388
                    Yes when reloading software the machine will have standalone settings
                    • spartanfangr
                      • Jan 2018
                      • 7
                      Great! I'm trying to locate the same version. I found a different version on xerox.com. Can I reload with a different/factory version?
                      • adriansto
                        • 2388
                        If is higher version it's ok.
                        If lower version with caution.
                        • adriansto
                          • 2388
                          • sureshraidu
                            • Oct 2011
                            • 28
                            This is spar vision.
                            Search xerox 5755 SPAR firmware.
                            You'll get this same version firmware.
                              ADMIN MODE
                              ACCT admin
                              passw 1111
