Xerox c550 045-312 and 045-360
  • sanimir
    • 183
    [Error Code] Xerox c550 045-312 and 045-360
    Xerox c550 045-312 and 045-360 error.
    Please some info or help
    THANKS
  • Mukasa
    • May 2015
    • 178
    Re: Xerox c550 045-312 and 045-360
    THANKS
    Cause: 45-312
    Damaged high voltage lead on 2nd BTR assembly causing arcing and electrical noise.
    Solution: [IMG]pws://file/xrxdata/xpws/templates/thumbsup.gif[/IMG] Fixed! [IMG]pws://file/xrxdata/xpws/templates/thumbsdn.gif[/IMG] Did not fix.
    Inspect the 2nd BTR high voltage lead on each end for damage.
    Ensure that the connectors are securely attached to the wire on each end. In most cases the connector is only attached by a couple of strands of wire, the rest of the strands look like they were cut when the connector was crimped onto the wire.
    Repair 2nd BTR high voltage lead or replace the 2nd BTR assembly (PL 4.1 item 3).
    45-360
    check the fiery software
    • sanimir
      • 183
      Thanks man, you are great.
      Originally posted by Mukasa
      Cause: 45-312
      45-360
      • sanimir
        • 183
        now i have this isue witj settings, left is hewywight3, left its coated1
