wc 7225T, initial install, SIM card check, non customer mode
  • VegasTech
    • Feb 2018
    • 8
    Hello all,
    What have I gotten myself into? I found a Xerox wx7225T for sale on the web, brand new. I've been called on to set up Xerox/Ricoh/whatever printers in the past when it comes to network config/address books/scan to SMB. I figured I would just power this device up, set an IP address and be (mostly) ready to go. Not the case.
    Again, brand new machine still in wrappings, with a sealed package dating 14-Jul-2014. Unpackaged everything and powered it up, at that point I was given a 'Xerox tech installer' or 'Customer install'. I chose Customer and the device is attempting to check for a SIM. There is none. The only option is to re-check or power down. I'm stuck in this endless loop.
    Below are some troubleshooting/paths I've been working. These are meant to show I have attempted to fix it myself but have had no luck. If there is any more info needed, ask and I'll get it!
    * I tried getting into Diagnostic Mode, power on while holding 0 + Start, I could never get in there, same SIM failure page
    * I would be happy to try the Diagnostic Mode> clear NVM 614-010, but I can never get to that page
    * there is a battery somewhere in the printer, maybe sitting around for 3.5 yrs and the little battery is dead, where is it, what's the model number, and I'll order a new one
    * on power up it does show XXXXXX XXXXXX while it is in POST
    * the installed firmware is 72.034.09100
    * I've tried booting with and without a network cable
    * on the in connectivity panel (network/USB/SIM) there is a steady blinking dot on the single digit indicator, at various time during the boot cycle it shows C d A
    * I can connect to the webGUI and it looks fine, I can change settings (admin 1111)
    * the status at webGUI says Machine is Diagnostic Mode, auto-cf gs disabled, pls wait for machine exit Diag mode, the machine is unavailable, 22-505-17
    * can I upgrade the firmware via the webGUI with the hope this will reset the printer's initial cfg
    * I have another 7225T printer still boxed up, what can I say it was a good deal, do I chance powering that one on and trying 'Xerox Tech installer'?
  • VegasTech
    • Feb 2018
    • 8
    Re: wc 7225T, initial install, SIM card check, non customer mode
    OK, I can get into Diag Mode, the option that worked for me is
    1. hold 0 for 5 secs
    2. while still holding 0 press Start button
    3. release both
    So what's the best option?
    * initialize
    * change dc301 NVM 601-014 value ot 4
    • VegasTech
      • Feb 2018
      • 8
      Or
      * dc131 NVM Read/Write > enter 616-014 >> change the value to 2
      • VegasTech
        • Feb 2018
        • 8
        So I chose the NVM Initialize option. After reboot that took me to a normal screen/boot. It still shows a msg about SIM card required and it says copying and printing disabled.
        From there I chose the NVM Read/Write of 616-014, set value to 2. That memory point references the Install Phase Mode (? doing this from memory now). It was 0, when set to 2 to went back to the original printer boot mode asking for Tech Installer or Customer. This time I chose Tech Install. After reboot it is back at a SIM request screen. Slightly different verbiage.
        • VegasTech
          • Feb 2018
          • 8
          Any help would be appreciated.
          • adriansto
            • 2387
            Go to Xerox web site to support and documentaion menu for your machine and read the installation procedure
            • jhalfhide
              • Apr 2015
              • 454
              • prismtech
                • May 2014
                • 199
                1-800-ASK-XEROX
                It's SIM time.
                These machines are pay to play. No SIM, no print.
                You bought a paper weight.
                • VegasTech
                  • Feb 2018
                  • 8
                  Argh, thanks for the info. Any idea what is expensive? Is that $1000 or $5000? Thankfully I know a Ricoh guy who gave me a lead on a Xerox guy.
                  I'm guessing a good amount of the techs here are real life copier techs. Any opinions on whether me buying an initialisation kit is cheaper from a dealer or direct from Xerox? Right now the 7225T do not have the fax module. If I buy one of those do I also need a license for that?
                  • VegasTech
                    • Feb 2018
                    • 8
                    Originally posted by prismtech
                    1-800-ASK-XEROX
                    It's SIM time.
                    Thanks, I'll give them a call.
                    • VegasTech
                      • Feb 2018
                      • 8
                      I've been looking around online and I found
                      Wc 7225i Initialization Kit W/ Bim Xerox Iscs Exclusive 097S04692
                      Any idea what a BIM is? Is that Xerox's name for a SIM? Most places I found were sold out so I imagine it will be a direct from Xerox order.
                      • prismtech
                        • May 2014
                        • 199
                        You don't buy an activation kit. The SIM is supplied by your Xerox dealer when you buy the machine.
                        That's why the part number is "sold out".
                        Buy a used machine and use this one for parts.... or suck it in, call Xerox and pay per copy.
                        • jhalfhide
                          • Apr 2015
                          • 454
                          • mrizer
                            • Mar 2009
                            • 70
                            I am having a similar issue with a 7225. We received 9 and one is missing the enablement SIM. Did you have any luck with Xerox?
                            Michael Rizer
                            Free Technical Support
                            Item Inc. 800-367-4836
                            mrizer@iteminc.com
                            • jhalfhide
                              • Apr 2015
                              • 454
                              Only solution is to order an initialisation Kit which is more that the value of the machine.
