xerox 7435 power on problem
  • Eng.Bebo
    • Jun 2025
    i have a problem with xerox 7435 color machine power on..
    after powering on ... machine fans sounds on and top cover intializes , but UI screen is off and no any loading
    i tried to clean ram and ps kit and the controller but no way... occasionally one time i tried to power on i found it worked good with any reasonable reason but one day and gone back to black ui.. any advice ??
    Re: xerox 7435 power on problem
    start with current firmware.. you should do it via altboot
    • sureshraidu
      • Oct 2011
      • 28
      Try replacing memory RAM
      Sent from my F5122 using Tapatalk
