xerox Acolor 936
  • smiley
    • Aug 2008
    • 616
    xerox Acolor 936
    hi all can you -please help me of these machine it has an error code 3-304 this machine never been use over 3 years.
    there is no glory without sacrifice
  • xcopytech
    • Aug 2006
    • 1792
    3-304 RAP
    Description
    Communication failure between the UI System Control PWB and the Control Panel.
    Initial Actions
    Verify that the IIT Fan is operating properly.
    Procedure
    1.Go to FLAG 1 and check the harness for an open or short circuit.
    2.If the harness is OK, replace the UI System Control PWB ( PL 9.2 ).
    3.If the problem is not corrected, replace the Control Panel ( PL 12.2 ).
    • smiley
      • Aug 2008
      • 616
      thanks you xcopytech. do you still need of ir5000n system?
      • xcopytech
        • Aug 2006
        • 1792
        thanks, i get it.
        br
