wc 7535 stuck in processing job...
  • estqwerty
    • Feb 2018
    • 8
    Hi i have processing jobs on screen after a huge pdf, and yep no printing at all. copying is working.
    its 7535 but as i search the internet is common for all 75xx series.
    still did not found a solution.
    can someone explain me the altboot options...
    I wish to try to boot from usb without mess it up with the firmware on the machine is it possible?
    Howto first backup all the settings from the machine?
    Thanks.
  • adriansto
    • 2383
    Re: wc 7535 stuck in processing job...
    Altboot from usb stick is used for reloading machine software.
    Better is to reload same software version.
    • estqwerty
      • Feb 2018
      • 8
      Is there a way the altboot to mess the nvm?
      I am able to backup the nvm to HDD but can't get it on the usb.
      This is why I am afraid to altboot.
      Can I download nvm backup trough the network?
      What else I need to backup from the machine?
      • estqwerty
        • Feb 2018
        • 8
        Thanks ! altbooted and now printing again.
        nvm backup worked on the back usb.
        No mather i give the FORCED_UPGRADE the printer remembered the IP settings? Also no need for restoring nvm. Everithing just worked after a long around 50 min upgread.
