5875 reduction and enlargement
  • shaahin
    • Jun 2017
    • 26
    Hi all
    When i use reduction or enlargement i have very movement in copy and print .
    how can i fix it.
    thanks all
  • Edib Vektor
    Everything can be solved
    • 15
    Re: 5875 reduction and enlargement
    Hello, are you copying something like book?
    You have option below reduce/englare that it have checkmark "AutoCenter", you should check it.
    Also, try to print something that just have square lines on page, so you can see if you need to adjust IOT Registration.
