XEROX 7556
  • tarikdaoudi
    • Aug 2016
    • 11
    XEROX 7556
    hi to all
    need help on xerox 7556 on screen this message
    the machine is not available please wait ........the systeme is attempting to recover.
    i upgrade the os to the laste version .same probleme .in historique incident
    391.973.00
    391.928.00
    391.929.00
    thank you for any suggestion or advice on this tte failure
  • shaahin
    • Jun 2017
    • 26
    Re: XEROX 7556
    Hi
    Check the fuser and main low voltage.
    • tarikdaoudi
      • Aug 2016
      • 11
      Re: XEROX 7556
      thank you chaahin for your interest in my problem. I have already change the fuser same message.
      other solution to this headache
      thank you
      • shaahin
        • Jun 2017
        • 26
        Re: XEROX 7556
        thank you
        I can't find 391-973 fault code
        391-928 is magenta crum fault
        391-929 is cyan crum fault
        change M&C crum chip or replace M&C drum cartridge.
