Xerox Colorqube 9301 Error 089-520
  • LamsterPaul
    • May 2014
    • 46
    have someone a hint where the fault was or knowing Issue, for the Error 89-520-00 Home Sensor Timeout RAP ?
    DC625 Calibration also will not work
    thanks
    Paul
    Re: Xerox Colorqube 9301 Error 089-520
    thanks
    Paul
    of course the calibration won't pass .. you have an error ... that must be cleared first... hopefully you have the SM ( never go out on a xerox without one )
    • LamsterPaul
      • May 2014
      • 46
      Yep, has a service manual,
      have working the process trough, but the error will still come back,I think the sensor or the unit was faulty, so i order a new one, and hope it will work
      • prismtech
        • May 2014
        • 199
        thanks
        Paul
        This is usually caused by paper dust clogging up the home sensor on the registration pre-heat assembly.
        Clean the sensor.
        If that doesn't work replace the entire regi assembly. Takes five minutes.
        I have a whack of these used to swap in when they get dirty.
        Cheap paper will cause this error within 20,000 copies.
        • Odin
          • Jan 2019
          • 5
          Hi, I have a Xerox CQ 9303, the same problem appeared 89-520-00 Home Sensor Timeout RAP. I performed the DC330, both motors work well, when the shaft is turned manually, the sensor responds (HI (x), LOW (x)). But the problem does not disappear. I have SM Need help pls.
          • LamsterPaul
            • May 2014
            • 46
            Hi, I replace the complete PreHeat Assembly (801K37710) and the fault was gone
            • Odin
              • Jan 2019
              • 5
              yes, of course, the problem should disappear after that
              Maybe there is an option to repair this unit
              • prismtech
                • May 2014
                • 199
                You don't repair the registration assembly. You throw it out and get a new one.
                Garbage is garbage, and these units get old and brittle. Sensor flag breaks off home drive gear, etc.
                Toss it.
                Sent from my SM-T530NU using Tapatalk
                  you really should start a new thread.
                  • Odin
                    • Jan 2019
                    • 5
                    Thanks to everyone, I will look for a replacement.
                    • Odin
                      • Jan 2019
                      • 5
                      Maybe someone will be interested. I found the problem why this device stopped working. The little plastic gear cracked.
                      • Elsava
                        • Oct 2021
                        • 3
                        • adriansto
                          • 2387
                          On service manual the procedure is described. Send mail stoadis@gmail.com if you need the sm.
                          • Elsava
                            • Oct 2021
                            • 3
                            Clean the sensor.
                            Where can i get a new one of 801k37710?
                            I can‘t find it.
                            • Tecnico_Xerox
                              • Jan 2019
                              • 54
                              Hello.
                              put the part number in Google. I found 2 options.
                              801K37710, 607K10840, 641S01042 - Xerox Colorqube 9201, 9202 Item Inc. (iteminconline.com)
                              Nuevo conjunto de precalentamiento de registro para Xerox ColorQube 92xx 93xx - 801K37710 | eBay
                              Luck
