Xerox 5755 Paper Jam solution
  • ouraimscom
    • Aug 2016
    • 13
    i have xerox wc 5755 when i was printing double side more than 2 papers it's struck in the middle of heat unit the paper was folded i was asking my useless local machine service man they say need to change paper quality ( i was using 70 gsm) then i changed to 80 Gsm but still that problem has then i realized that's not paper problem so i came here kindly help me to resolve that problem because i huge loss on every month for that problem
    Re: Xerox 5755 Paper Jam solution
    sounds to me that it is jamming in the fuser ... correct?
    replace fuser
    • pearlpdy
      • Jul 2008
      • 44
      check registration clutch and clean corona and check exit sensor ok, problem solved
