xerox 5632 fusing
  • Gab
    • Aug 2015
    • 668
    xerox 5632 fusing
    message temperture Error at fusing unit .
    I checked lamps and thermofuses and they are ok i suspect thermistors.
    Fusing unit rises the temperture .
    Is thermistor the problem or something else ?
    Can i use machine at this condition without replaceing anything.
    I am a Ricoh tech and not so familiar with xerox machines. Thanks.
    Re: xerox 5632 fusing
    please give us the actual error code... but no I would replace fuser
    • Gab
      • Aug 2015
      • 668
      As i told you the message is "temperture error at fusing unit"
      and under is the message
      a) printing function is not available
      b) If problem insist call for help.
      I tried to make copies but i could't
      BEcause i am o Ricoh tech i don't know if somehow an error code appears and what do i have to do to see it.
      I suspect thermistors.
      Replace the whole unit is not an option for customer.
        precision roller has them for 129.99
        Xerox WorkCentre 5632 Fuser Module Assembly - 110 / 120 Volt, Genuine (A9398)
        • adriansto
          • 2383
          My opinion is the fuser unit from Ricoh copier do same thing as fuser unit from Xerox copier.
          So , if you are tech, you need what to do in this situation.
          Also I have a great doubts the fuser can work into Ricoh machine when thermistor is bad.
            I've been a Xerox Tech since 2002... there is 99.9% of the time a numeric code giving the EXACT issue. only when the consumable ( fuser ) is near/EOL do you only get a message.
            • Richard.Xerox
              • Jun 2015
              • 73
              Should be an "active messages" or "fault history" sections somewhere in the UI, this will give codes.
              Anything starting with a 10 is fuser related.
