Xerox Versant Jam After NVM INT
  • MRJESSE
    • Jun 2017
    • 54
    Have a Versant 80 the had its NVM SYS, USR & IOT INT. Since them, documents over 1 page jams just before getting to the 2nd BTR.
    No physical reason for the jam, looks like an error with the sensors.
    Any suggestions?
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox Versant Jam After NVM INT
    Did you save the NVM before you did the restore?
    • aneudimadera
      • May 2014
      • 30
      I saw that issue on Xerox color 560 after NVM init, it's just an NVM for the use of transparencies that need to be changed.
      Any suggestions?
      Enviado desde mi Nexus 6 mediante Tapatalk
      • Dech
        • Aug 2014
        • 48
        742-367 Paper Type Detection Limit (Transparency Operation Limit) Sets the Paper Type Detection Limit (Transparency Operation Limit). 0: Can operate, 1: Cannot operate
        This parameter is fixed to [1: Cannot operate] as the Trasparency Sensor related component has been removed.
        Set it to 1
