Nuvera License
  • Caffeine
    • 391
    Nuvera License
    I might be picking up a 1st generation Nuvera 120 to "play" with a bit... It's licenses have expired. Does anyone know what it would cost to get new licenses for this model? Feel free to PM me if you have any information.
    Thanks very much!
  • XeroxTechBrazil
    • Aug 2008
    • 198
    Re: Nuvera License
    Contact me for a free temp license to get you started.
    Email is best contact.
    Older Nuvera is a real PIA, new ones are so much better.
    It's actually turned into quite a nice machine. Took a few years.
    • Caffeine
      • 391
      Re: Nuvera License
      Thanks! That's very kind.
      I may pass on the machine, you and a couple of others have pointed out just how 'rough' the early Nuvera's were... And this one is earliest version.
      I got nervous anyway when I saw the modification "TAG" list was a couple HUNDRED items long...! haha
      • XeroxTechBrazil
        • Aug 2008
        • 198
        Re: Nuvera License
        In all fairness to the product,, they finally did get it right, and the new ones are strong runners.
        I have some clients in Brazil who want to replace their MICR DTs and DPs with Nuvera. I have no idea if that will be possible,, but it shows the confidence they have in the Nuvera.
        I was doing Docutechs when the Nuvera came out,,, quite a few went in to replace mostly 6135's. The promise of higher resolution, quieter, smaller footprint.
        Those things were true,,,, but much was left unsaid.
        Any number of customers insisted on getting their DocuTechs back. Belt life was only 300K back then,, and that was just one of the many issues associated with the product.
        • msheno01
          • Mar 2020
          • 11
          Re: Nuvera License
          Hi Do you happen to know how I can get a freeflow license for nuvera 100ea 3rd gen?
          • XeroxTechBrazil
            • Aug 2008
            • 198
            Re: Nuvera License
            Sure,, I just did two nuveras for a client in Brazil. I need your HostID and software revision.
            You can run that machine at 144 speed if you like,, the only difference between a 100 ppm and a 144 ppm machine is the license.
            To get the Hostid,, easiest is Top Toolbar, Help, About
            On the Nuvera, the only way to be 100% sure of the software revision is to look at the lower left corner of the License Manager. There will be a number in black there,, probably 7.1 or 7.2 for your flavor of machine.
            Top Toolbar, Setup,, License Look in lower left corner for the software revision
            Turn time is 24 hours after payment.
            Best is to contact me via email,, JorgeXcalak@live.com
            Email me for WhatsApp if you need to talk to me
            Thanks for your inquiry
            John
