Getting this jam code from tray 6 on the high capicity feeder. Going to order in one of the transport clutches. Just wondering if anyone has seen this before?
Xerox D110 fault 078-100
Re: Xerox D110 fault 078-100
If its jamming at the feed head of the IOT, check and see it (feed head) is has rolls or if its a slot. -
My (020K 10940 One Way Clutch Pulley (39T) x2 were the problem to my jams. replace both of them.. Comment
You would need to take the HCF off. The baffle should not have a feed gear or 2 rolls where the paper enters the printer. These rolls are not needed with a HCF only with a Tray 5.Comment
