9301 ColorQube... Boot Loop green splash screen / Altboot wont load?
  • prismtech
    • May 2014
    • 199
    Re: 9301 ColorQube... Boot Loop green splash screen / Altboot wont load?
    3-2-1 is the standard flash pattern.
    Stop messing with it and save it for spare parts.
    It takes three to four 92xx / 93xx machines to keep one running.
    • prismtech
      • May 2014
      • 199
      As a side note you can't swap hard drives from colorqube to colorqube. The drive from the working machine will never boot the other unit. It will just sit and spin for 20 minutes followed by a power off message.
      • prismtech
        • May 2014
        • 199
        Side note #2. The 92xx colorqubes only alboot with USB 1.1 or older usb sticks. The 93xx range will altboot with USB 2.0 and down.
        • eunuch39
          • Aug 2014
          • 40
          #19
          Originally posted by prismtech
          I work in the GTA and service these machines exclusively.
          I also have full spares ava.
          Contact me if you are looking for ColorQube service.
          on front cover to the left is a little plastic piece that comes out look in there for a green light when you turn it on then watch the flashing red light does it do a 3 rapid then 2 rapid then 1 then flassh rapid again? if so it means engine is fine its software
          • CanadianEH
            • May 2018
            • 11
            #20
            Originally posted by [COLOR=#3E3E3E
            prismtech] A[/COLOR]s a side note you can't swap hard drives from colorqube to colorqube. The drive from the working machine will never boot the other unit. It will just sit and spin for 20 minutes followed by a power off message.
            Originally posted by adriansto
            Move hdd from working machine to the other one and watch what happen.
            Adriansto said this isnt a problem. to swap the HDD. is this correct or not?
            It forsure is a 9301 and have used multiple new and older USB drives. The usb drive I used most recently had a LED light on showing that the drive was being accessed while plugged in ( blinking like a HDD light, not steady) but still didnt seem to boot the machine.
            When you turn the machine on.. it makes seems to make all the same noises as the working one. like it is initializing. just seems to stick and not fully load up software. Should I try a force upgrade instead of altboot?
            On the side note of this
            Can I remove the printheads and put them into my working machine? I have a slight light stripes issue on the working one. ( not a huge deal but would be nice to be gone)
            • prismtech
              • May 2014
              • 199
              #21
              1.) You cannot swap drives between units and expect them to boot. Only with a fresh altboot would the swapped drive load. There is a process that happens during the drive encryption that locks it to the machine. If you try this between a connect key machine and a non connect key machine you will brick the LCD screen (UI).
              2.) Breaking a print head off of the marking unit to swap is a last resort. It is 50:50 wether it will reseal to the other machine. Most times you kill them.
              3.) Swap the entire marking unit from machine to machine whilst also swapping the nvram module from the IME.
              4.) If you really wanted to altboot your bricked machine, you would stop messing around and find a 500gb SATA drive from a laptop that is surfaced scanned good. You would then plug it into the machine in place of the 320gb that is currently there. Place USB stick fat_32 format with the altboot directory into the REAR of the machine. Done. No using a sata drive that has ever been plugged into another copier.
              If that doesn't work, you are in over your head. Ie. Bad battery on the MPU or something else that takes a Master tech to fix.
              • CanadianEH
                • May 2018
                • 11
                #22
                I will try that procedure in #4 again.
                On a side note... there was NO HDD in the machine at all. It had been pulled out before we bought them as per the previous owners policy. ( one wasnt inside when we got them.) The Altboot procedure worked from USB on the second machine and a 320GB Laptop drive that I put in.
                Is it possible to swap the whole motherboard with the working machine? to see if we can get it going?
                What does that little sim card on the back of the machine do what if we swapped those?
                When you say to swap the entire marking unit, do you mean the entire 24" x 14" x 12" unit on slides that comes out of the front of the machine? ( contains all 4 print heads, wax reservoirs etc?)
                Not just this piece?
                • prismtech
                  • May 2014
                  • 199
                  #23
                  [ATTACH=CONFIG]40928[/ATTACH]
                  1.) Sim card doesn't do anything in your situation.
                  2.) Don't waste your time swapping the main engine motherboard, your only going to brick the other one too.
                  3.) Try another hard drive other than any you have tried before. Even one bad sector will cause it to do exactly what it is doing to you.
                  4.) The box on slides is the marking unit. The only positive thing about these wretched units is you can swap the entire thing between colorqubes. Nvram on the ime needs to swap at the same time. Ie. The little chip on the back of the marking unit.
                  Sent from my SM-T530NU using Tapatalk
                  • CanadianEH
                    • May 2018
                    • 11
                    #24
                    Sounds to me like you REALLY like these machines and they are your favorite to work on.. Haha
                    I am going to buy a new HDD today... instead of using one sitting around. Ill try that and report back. I have a feeling the result will be the same.
                    If I remove the marking unit and plug it into my working machine, will it show the original number of prints for that marking unit? or will it reset at zero?
                    Anything else I should know about removing that marking unit and putting it into my working machine to try it? Ill see if I can find the little chip your talking about before removing. Just to get this right, I should be able to swap the entire marking unit back and forth with no issue to the working machine?
                    Thanks everyone for all the help.
                    • prismtech
                      • May 2014
                      • 199
                      #25
                      The problem is they're prone to cascading failure. You poke at it too much for one issue, you will break something else.
                      The copy count is stored on the main board up top, not the one on the marking unit.
                      You can swap the marking unit back and forth but like I said every time you poke at it you are throwing the dice. The print heads in that unit are probably shot too. Most colorqubes start streaking in the first three months or 20,000 impressions. It's pretty well hopeless to try and get them printing clean. Swap the marking unit only after the reservoir or umbilicals have blown.
