replace magenta toner message on xerox wc 7855
  • Sema
    • Apr 2016
    • 36
    Hello friends
    I have a xerox machine workcentre 7855. It shows replace magenta toner message on the screen yet toner is there i the toner container.
    I thought it could a defective chip, replaced another toner but it didnt work out.
    I serviced the the toner despense unit for any brokage, all was clear.
    To make matters worse some times it reads when you touch on the toner despenser. I don't know where the problem is exactly , i need some help.
    Regards
    Sema
  • abdou
    • 39
    Re: replace magenta toner message on xerox wc 7855
    I think that you have problem with dispenser toner assembly magenta, the toner not arrives in the develepporer module
    • rockdude
      • Feb 2011
      • 257
      Verify it's actually Xerox toner! Not Compatable!
      I had a similar problem, turned out to be a counterfit Xerox toner tube.
      Good Luck.
