Xerox DC 252 magenta developer unit problem
+ More Options
Posts
  • sanimir
    • 183
    [Jamming] Xerox DC 252 magenta developer unit problem
    Nylon on the developer unit its broken, i replace with other one and nylon again broken.
    Thanks for advice
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox DC 252 magenta developer unit problem
    Yes its the same on all of them
    • sanimir
      • 183
      i put new nylon on magenta developing unit.
      Not sam on c, y or k
      • JrTech
        • Jun 2013
        • 217
        Did you use the same developer unit and just replaced the nylon? If so I would suggest you get another developer unit and start fresh. You can re use the developer a few times (2x max for me). If you dont use generic toner, just vac out and reload fresh powder.
        Hope this helps
        • abdou
          • 39
          if the nylon is brocken in the same place I think that you should check that the developpeur unit is intalled correctely try to emply the developpeur module and intall a new develloper materiel
