workcenter 5632
  • Gab
    • Aug 2015
    • 671
    workcenter 5632
    Machine shows writes to wait fusing to warm but it doesn,t warm and error in fusing unit appears.
    I suspect problem at power supply ( Also at the same period a kyocera machine at the same electric line had problem at power supply). Can it be something else?
    Fusinh\g unit is ok because i swapted an other warking fusing unit and had the same problem.
    And if problem is at the power supply
    Can anybody tell me how to remove power supply. I removed back cover, waste toner , high voltage board.
    It lools that it removes all with main board but somewhere stucks.
    I am a ricoh tech so not familiar with Xerox
  • shaahin
    • Jun 2017
    • 26
    Re: workcenter 5632
    Hi
    The control of fuser is in the low voltage unit.
    if fuser is good so change the low voltage unit.
    • Gab
      • Aug 2015
      • 671
      Re: workcenter 5632
      Originally posted by shaahin
      Hi
      Low voltage unit is behind high voltage board?
      • abdou
        • 39
        Re: workcenter 5632
        it can caused by two problems first you must check the connector of fuser module if he docking corectely or you change LVPS( low voltage power supply) to remove il you should remove the rear cover after remove all connector of HVPS, lvps and main pwb after there is a screw in middle between main pwb and hvps you should also remove wast toner bottle and wast toner support bottle
          Re: workcenter 5632
          if you don't have a manual for it, I would suggest either getting one or dropping that machine like a hot potato ... there are steps in the manual YOU MUST follow to avoid other problems.
