activation code
+ More Options
Posts
  • Reeves
    • Apr 2012
    • 294
    [Error Code] activation code
    i have a xeox wc 7535 displaying register supplies using Activation Code. Anybody help me this code.
  • kawessa
    • Jul 2018
    • 6
    Re: activation code
    Save nvm for that machine on a usb drive then remove the battery(yellow lithium battery) on the nvm pwb inside ess for 5 minutes and then reinstall and problem solved
      Re: activation code
      if the battery is failing you need to REPLACE the battery
      • adriansto
        • 2383
        Re: activation code
        What did you changed to the machine ?
        Trying to use another type of toner ?
          Re: activation code
          that sounds like what he did...
          • Reeves
            • Apr 2012
            • 294
            Re: activation code
            Thanks how do I save NVM on the usb without using PWS how do I save direct from the machine
            • rockdude
              • Feb 2011
              • 257
              • joelsd619
                Re: activation code
                I'm having the same issue. I've been using aftermarket toners on a metered machine. If it's the toners that are causing the error, will it resolve itself if I go back to using genuine toners?
                Also, I was not able to find the "toner card" on eBay. Would you happen to have a link?
                I would REALLY appreciate your help!
                Thanks!
