ColorQube 8570 - Jamming, Poor image quality
  • harps05
    Field Service Engineer
    • Mar 2012
    • 114
    Hi All,
    I hope this is in the correct forum as I couldn't find a Xerox category in the Printer Forum.
    My background is mainly Sharp MFC's so looking at these ColorQubes' usually have me tearing my hair out.
    Apart from our main Sharp work, we also do 3rd party contract work which see's us looking at a broad range of makes.
    This machine in particular seems to be jamming every 2nd or 3rd page. Print quality is terrible, after the user told me he wiped the drum.
    So I have the following parts ready to go in:
    • Drum assy
    • Printhead wiper
    • Drum maintenance Kit
    • Drum Wiper Blade assy
    • Pick assy
    • Out Takeaway guide
    Replacing these parts isn't my problem. My problem me is that when I arrived at the site they had the Drum maintence Kit removed and it would not go back in. I had to boot the machine and when the blade assy lowered I pulled the power plug to be able to refit it. When I returned today to fit a new one, I could not, simply, remove it without going through the same process. I'm wondering if it's a timing issue that is contributng to the whole jam, print issues. Although, the machine powers on fine and comes to a ready state as normal with no error codes at all.
    Would love some input.
    Thanks everyone.
    Re: ColorQube 8570 - Jamming, Poor image quality
    Originally posted by harps05
    Hi All,
    • Drum assy
    • Printhead wiper
    • Pick assy
    Thanks everyone.
    with the broad array of parts you are getting... the customer could have bought a new one.
    what is the jam code? where is it jamming?
    do you have smears or streaks? there is procedures in the machine for quality issues.
    • rockdude
      • Feb 2011
      • 257
      Process Drive and timing. No. 1 (Please install stabilizer bushing as well)
      2. D.M. Cam Shaft (Cracked) also check the timing
      3. Feed Roller Kit (The one that snaps into place)
      4. Media Gear Drive (Cracked Gears)
      5. Pre-Heater Desqew assembly
      6. Y-Axis Drive belt
      After the above it could be anything from broken flags, crimped orbroken wires, bad sensors, etc.
      (If not the above the Jam Codes are a must)
      As for blurry crappy print:
      1.
      2. Bad Maintenance kit
      3. Pre-Heater Deskew (Garbage caught in between metal slot)
      Bad X-Axis Motor
      4. 1.
      Printhead
      2. Wave amp board or cable
      3.
        Originally posted by rockdude
        1. Process Drive and timing. No. 1 (Please install stabilizer bushing as well)
        1. 2. Bad Maintenance kit
        Bad X-Axis Motor
        4. 1. Printhead
        3.
        totally agree with rockdude ( bout the same yrs in solid ink in .. **340=PIG** ) BUT for PQ start with the internal cleanings..jet sub.
        jamming can be ( with ANY printer: Rollers - de-skew (reg) or bits of paper)
        just wondering... what did they clean the "drum" with and did they mean the MAINT Roller?
        process drives MOST times grinds like a hooker in your lap
        but like I said before this is going to be an EXPENSIVE repair UNLESS you can return unused/needed parts
        • harps05
          • Mar 2012
          • 114
          Sorry for the late reply guys. I appreciate the time.
          OK, I have replaced the Drum unit, drum cleaning blade and the print head wiper.
          I have the print head, wiper blade and process drive all lined up and in the home positions before start up. After start up, during warm up I'm getting a grind in the process gears and the printhead shift motor.
          Error codes that I have seen are:
          94,700.00:85425
          94,700.00:85417
          89,572.00:85425
          If I start up without the printhead maintenance kit installed, it gets all the way thru the warm up, with no grinds what so ever. If it's in, grinds and error codes.
          Can someone have a look at the attached pics and tell me if the cleaning blade assembly should be in this position when the process gears have been aligned.
          Any tips would be appreciated.
          • rockdude
            • Feb 2011
            • 257
            • harps05
              • Mar 2012
              • 114
              Thanks for the reply Rockdude. No I haven't replaced the the DM camshaft. And I will double check these home position pointers.
              I had read about the Print Head tilt gear train posts tendency to crack.
              Thanks again mate, I shall report back later.
              • harps05
                • Mar 2012
                • 114
                So after replacing the drum, cleaning blade it was giving me constant 94,700's. After disassembling today I realised there seemed to be to much pressure on the resist roller arms, preventing free movement. This seemed to be caused by the drum unit having been tightened with too much rear biased pressure.
                All good now, appreciate the input.
                Thanks Guys.
                • rockdude
                  • Feb 2011
                  • 257
                  If it should suddenly comeback again, try changing the Y-Axis belt.
                  Good luck.
