77-909 C 560
  • bojans
    • 1313
    77-909 C 560
    Trying to solve problem remotely.
    Customer is getting error 77-909 on C 560, but only if print/copy in color mode. BW mode works ok.
  • adriansto
    • 2383
    Re: 77-909 C 560
    Check your inbox.
    Sent you mail
    • bojans
      • 1313
      Re: 77-909 C 560
      Thank you.
      We followed procedure and checked all sensors.
      But as I told before, machine was working in BW. It getting this jam when print in color.
        Re: 77-909 C 560
        Thank you.
        Xerox(R) DocuColor™ 700 550 560 Fuser Exit Switch Actuator 640K88769 - Xentair
        yes it may work in B&W mode... there isn't as much toner on the page which in turn will allow it to pass thru quicker. the found solution is the fuser exit switch actuator. It could be looking and acting fine in B&W but bomb in color mode.
        • bojans
          • 1313
          Re: 77-909 C 560
          Fuser is OK.
          Checked in other machine, also swapped with other working.
          • adriansto
            • 2383
            Re: 77-909 C 560
            Fuser is OK.
            You need to check the reflexive sensors not the ones with lever.
            • knightfall
              • Jul 2006
              • 633
              Re: 77-909 C 560
              Are you jamming after the registration unit but before the fuser unit, if so did you replace the 2nd btr?, there was a setting in nvm for that problem but can't find it now
              Get your facts first, and then you can distort them as much as you please.
              • bojans
                • 1313
                Re: 77-909 C 560
                That's the place where it jams.
                If you find that nvm, please post.
                • bojans
                  • 1313
                  Re: 77-909 C 560
                  Got that nvm.
                  Problem solved.
                  Thanks Adrian.
                  • ablepe
                    • 40
                    Re: 77-909 C 560
                    Can I get that nvm setting?
                    Sent from my Lenovo K33a48 using Tapatalk
                    • bojans
                      • 1313
                      Re: 77-909 C 560
                      Naravno.
                      742-180
                      • ablepe
                        • 40
                        Re: 77-909 C 560
                        Hvala
