Xerox WC 3345 reboots
  • omni
    • 30
    Good day. We have an issue with WC 3345.When sending files via network port MFP reboots. And via USB all works fine.Updated firmware with no results. Problem still exists.
    Thanks in advance.
    Re: Xerox WC 3345 reboots
    Thanks in advance.
    what happens when you ping the unit from a workstation?
    are there any error codes recorded?
    • omni
      • 30
      There are no error codes that can cause reboots, when I ping MFP from workststion ping losescwhen unit reboots.
      • rockdude
        • Feb 2011
        • 257
        So to be clear it "Does" or "Does Not" reboot when you ping the MFP?
        Also try different IP address for MFP and let us know what happens?
          OF COURSE you will lose connection when the machine reboots! there are REASON it reboots and MOST times they are contained in the ERROR LOG>
          • omni
            • 30
            When I ping mfp it "does not' reboot. Error Log consists of jams and low toner errors, and no error codes that can cause reboot. MFP reboots when try to print via network port. Tried another IP and driver, problem still exists.
            • marvin_PL
              • Jun 2012
              • 24
              Did you solve the problem?
              • omni
                • 30
                No, it still remains. You have the same?
                • omni
                  • 30
                  • marvin_PL
                    • Jun 2012
                    • 24
                    Yes
                    • IGEN93
                      • Jul 2018
                      • 49
                      Originally posted by marvin_PL
                      Yes
                      initially check for the voltage and leakage current , there might be earthing problem from the lan cable , try changing the lan cable and check for symptoms . also check the lan port on the machine for both the led's are blinking or static .if the led on the printers lan port are steady and not blinking then remove the printer board and check the network IC for any damage or disturbance . surely there is some damage to the board.
                      • danservc
                        • May 2022
                        • 1
                        Thanks in advance.
                        • Alexandr
                          • Mar 2022
                          • 12
                          You need to go to Diag Mode. Find clearing memory. After the reboot, the device will turn on with the choice of language and country. The problem will go away.
