Docucolor 240 error code 045-312
  • almerico
    • Oct 2012
    • 58
    [Error Code] Docucolor 240 error code 045-312
    After changing the rom on my printer it had the corked controller. The printer gives me error 045-312. In the billingmeter the nvm IOT from all zero values and does not give me the possibility to enter the correct serial number of the machine.
    can someone help me?
    Thank you
  • adriansto
    • 2387
    Re: Docucolor 240 error code 045-312
    Thank you
    No / bad connection between MCU and IOT Drive - flat cable pj431
    • almerico
      • Oct 2012
      • 58
      Thanks, I try to see the flat cable if I'm okay, otherwise I have to replace them? if yes, where can I find them?
      • xcopytech
        • Aug 2006
        • 1794
        What did you replace?
        ESS NVM PWB?
        ESS PWB?
        MCU NVM PWB?
        • almerico
          • Oct 2012
          • 58
          ESS NVM PWB?
          ESS PWB?
          MCU NVM PWB?
          flat cable pj431
