Xerox 5765 alignment problem
  • Gulbadin
    • Nov 2017
    • 22
    I have xerox 5765 in duplex print the front print is upward from the back side
  • tarikdaoudi
    • Aug 2016
    • 11
    Re: Xerox 5765 alignment problem
    Can you poste exemple thinks.
      • 22808
      what have you done to it so far?
      has the machine been worked on recently?
      are all consumables in good shape? % left?
      how much of a difference in mm? industry standard is 2mm shift
      please measure and reply
      • JrTech
        • Jun 2013
        • 217
        You have a feature in duplex called flip on short edge. Turn it off and both sides should be same orientation.
        Hope this helps
