077-130 duplex out sensor on jam
+ More Options
Posts
  • Kawai
    • Jan 2015
    • 10
    #16
    Re: 077-130 duplex out sensor on jam
    I had same problem: So You have to clean all bearings where belt is running and also duplex rolls bearings. Dont add any lubricant (excess toner, paperdust). There may be problem that duplex mainshaft clutch is worn - teeths are worn. In that case You have to order new one beacause if all bearings moves freely and if You overtension belt then dup. motor stalls. If tension is normal clutch makes grinding noise. Look PL.4.5 item 13 pulley (attached picture) is there tooths OK. I made thread to know, what is a partnr. for this pulley. Partsmanual gives partnr. for all duplex upper chute.
    Try to hear does noise coming from left side of duplex. Duplex motor component control is 077-050.
    Greetings,
    • Kwaku01
      • Aug 2018
      • 121
      #17
      Greetings,
      [ATTACH=CONFIG]40818[/ATTACH]
      Thanks alot mate! Sorry for late response, being away.
      • Kwaku01
        • Aug 2018
        • 121
        #18
        Greetings,
        Hi Kawai/anyone,
        Thanks for your advice again. I've taken the belt and cleaned all bearings where belt is running and also duplex rolls. But I'm having a bit of difficulty putting the belt back on. Please would you happen to have a diagram of the belt on the rolls and bearings?
        Please, your help is greatly appreciated!
        • Kawai
          • Jan 2015
          • 10
          #19
          • Kawai
            • Jan 2015
            • 10
            #20
            imgur.com/a/N69uzPu
            • Kwaku01
              • Aug 2018
              • 121
              #21
              imgur.com/a/N69uzPu
              You are a champion! Thank you so much!!!
