Xerox 58xx speed
  • mkdirs
    • Oct 2014
    • 177
    Xerox 58xx speed
    hi all
    any idea ho can I upgrade Xerox 5845 to 55
    and how to upgrade 5865 to 75
    in 57xx models I know how to do I have the all NVM for this series
    thanks
    Xerotk.com
    xerox copier technician
    Re: Xerox 58xx speed
    Originally posted by mkdirs
    hi all
    thanks
    the cost ( if the parts worked ) would be cost prohibitive, and all for 10ppm more?
    • mkdirs
      • Oct 2014
      • 177
      what cost my friend its a software change
      its an nvm reload some thing like that
      Xerotk.com
      • jhalfhide
        • Apr 2015
        • 454
          i don't think he is a tech... and if he is ... not much of one... firmware or changing NV ram values will not change the speed... boards and other items .. ( mtrs ) will be required IF it can be done at all... alot of times there are connectors on the higher speed units that are not used on the slower ones.
          • mkdirs
            • Oct 2014
            • 177
            I am a xerox tech my friend i can change 57xx speed from 30 to 45 and 55
            And from 65 to 75 or 90
            The 58xx i have an idea i will try it on morrning
            No sim need and the pw or io board
            parameters located in nvm tabels
            Xerotk.com
              bullcrap
              no FRIEND here...
              done
              • jhalfhide
                • Apr 2015
                • 454
                • mkdirs
                  • Oct 2014
                  • 177
                  bullcrap
                  no FRIEND here...
                  done
                  there is a real tech guy and there is a bla bla bla mouth
                  so both of you talking with minimum experience
                  i change the speed without new sim card and i reset the counter
                  Xerotk.com
                    [ATTACH=CONFIG]40594[/ATTACH][ATTACH=CONFIG]40593[/ATTACH][ATTACH=CONFIG]40595[/ATTACH]
                    you are full of it.... I have been working on Xerox since 1999. Of Course I was CERTIFIED and never did the job half assed. I have been working on printers/copiers for 31 years.. so WHO has the " minimum experience " and take your bla bla bla mouth and shove it ... you are now on my iggy list.
                    • mkdirs
                      • Oct 2014
                      • 177
                      i think you are posting just to get a posting points
                      Xerotk.com
                        unlike you I do not need to do that. now ... IF you wanna get into thinking about what kind of tech or person you are ... we can play that game and much like the Clantons... you will be buried at Boot Hill.
                        • jhalfhide
                          • Apr 2015
                          • 454
                          • mkdirs
                            • Oct 2014
                            • 177
                            I did not replace anything even i did not take tha back cover out
                            its just a software i used same SIM
                            Xerotk.com
                            • JrTech
                              • Jun 2013
                              • 217
                              Everyone relax. Both are correct. Yes it can be done NO chance you will see this in the US. Here in good Ol USA we have way too much to lose and I have no reason to change speeds or be shady about Xerox as they sell themselves.
                              From where this person is located they get a slap on the wrist and call it a day. It does cause issues with crashing, consumable issues and is really not worth the headache. You can buy a used 57xx for $300 or a 58xx for $500, so a few extra dollars is not worth the service call which this person is looking to offload to customer.
                              Hope this helps with the confusion.
