WC 5865i Firmware upgrade
  • JLSam
    • Jun 2015
    • 605
    Long story short, Xerox Helpline advised me that this machine needs a software update to resolve a particular issue.
    Sure! I've done it plenty times before on previous models.
    So I download the firmware via support.xerox.com, download the manual upgrade, download the Manual upgrade. I copy and paste the 07319007534540 dlm file to USB(fat32) > altboot > FORCED_UPGRADE (no extension).
    I come back... who knows how long I didn't count. But it started saying "Device unavailable". And would reboot, again, and again in 10 minute intervals?
    Called Xerox, Rep says "Oh yeah, sometimes that firmware fails I don't use that one. Use this one, sends me a link to this file:
    Workcentre_5845-5890_system-sw07319004815000
    I repeat the process, and....It's been like this for over an hour. Haven't seen the upgrade form yet.
    Help would be appreciated.
  • jhalfhide
    • Apr 2015
    • 454
    • mkdirs
      • Oct 2014
      • 177
      Re: WC 5865i Firmware upgrade
      Try another USB
      If not
      Try to format HDD and altboot with 71.xxx.xxx
      Firmware if all ok upgrade to 72.xx
      Then to 73.xx
      Xerotk.com
      xerox copier technician
      • xcopytech
        • Aug 2006
        • 1794
        I think that you tried to install wrong firmware.
        You should download install firmware for wc5865i not for wc5865.
        WorkCentre 5865i/5875i/5890i Drivers & Downloads
        • jhalfhide
          • Apr 2015
          • 454
          Same firmware. No difference and the only difference between the i and non i is that the i came shipped with the newer software.
          • JLSam
            • Jun 2015
            • 605
            My USB does have an activity light. You can see it there on the picture. The machine was able to copy, but it did not print, for any computer, or any internal configuration reports. Thanks for the comment on the firmware, I was asking myself why Xerox Helpdesk would ask me to use a different firmware. So your comment puts my mind at ease.
            Originally posted by mkdirs
            Try another USB
            If not
            Then to 73.xx
            How can I format the HDD when I can't access the user interface? If I let the machine boot normally, it says "Device unavailable" now, and continues to reboot again, and again. I can only get the 72.xxx.xxx version. I'll start with that.
            Nevertheless, I am going back to that machine later, if anyone has any more ideas, your help is beyond appreciated.
            • jhalfhide
              • Apr 2015
              • 454
              • mkdirs
                • Oct 2014
                • 177
                To format HDD take it off connect the HDD to pc and format
                When problem with SD you will get a white screen
                Xerotk.com
                • JLSam
                  • Jun 2015
                  • 605
                  UPDATE: So, we took the machine to the office. Boot up time is horrendous.
                  So we tried the forced altboot again, not working. Stays in green screen. left it alone for 2 hours. same thing.
                  Before I try the PWS forced altboot, I'm going to try and format the HDD with my PC. What file system should I use? Fat32? NTFS? 16?
                  Any help, would be awesome.
                  • adriansto
                    • 2387
                    Low level format if you can,
                    If not, do chkdsk or fsck delete any partition from disk and do altboot again.
                    Check the cable & connections from hdd to motherboard.
                    • mkdirs
                      • Oct 2014
                      • 177
                      UPDATE: What file system should I use? Fat32? NTFS? 16?
                      Do not format ... just delet all partition dont creat a new on
                      Xerotk.com
