XEROX 700
  • tarikdaoudi
    • Aug 2016
    • 11
    XEROX 700
    hello everyone please i have a problem with a xerox 700 ON POWER STUK ON 3/6 HELP WILL BE GOOD
    THANK YOU IN ADVANCE
    Re: XEROX 700
    trying to understand your post.
    is the POWER button stuck?
    is it stuck on powering up?
    elaborate please
    • adriansto
      • 2387
      Re: XEROX 700
      If the XEROX logo appear then the problem is with UI.
      Check UI cable, reload UI software or replace UI
      • InterfaceP
        • Jun 2013
        • 488
        Re: XEROX 700
        If it wont get past 3 its a possible config mismatch, in particular if you just purchased it. Try booting with the finishing accessories disconnected. If this is effective note the serial #'s and I, or one of us can tell you where the problem is.
        Hope this helps
        • tarikdaoudi
          • Aug 2016
          • 11
          Re: XEROX 700
          elaborate please
          Thinks for all of you . Xerox power up at step 3 /6 and stuck .didn t continu her power 6/6.
          • mkdirs
            • Oct 2014
            • 177
            Re: XEROX 700
            try to power the xerox 700 with stop+3+power saver
            if not try stop+4+power sever
            if not replace the MCU
            Xerotk.com
            xerox copier technician
