wc 7535 developer problem in black
  • mmeldeep
    • Jul 2018
    • 8
    Please help I need to increase developer charging
    any help please
    Re: wc 7535 developer problem in black
    any help please
    why?
    more than likely the developer need replacing/rebuild
    • JrTech
      • Jun 2013
      • 217
      Wouldn't do that unless your trying to compensate for electrical. By your location I would say your not using 110v. As last post suggested you need to either rebuild or replace current. You can use a developer housing 2x just clean out old developer. If you increase voltage you are going to to try to developer and still have to replace entire housing as well as possibly gears. When developer is over charged it is hard as a rock and will break the motor. New developer is about $50USD. If your using Generic toner my suggestions are worthless and do as you wish to the machine. Only killers to these machines are generic crappy toner.
      Don't be cheap buy new developer charge and replace the housing. 17 screws to swap out unit. No reprogramming of NVM settings. Just replace, turn on and let the cycle run through. Run a few copies and your done.
      Hope this helps
      • mmeldeep
        • Jul 2018
        • 8
        Hope this helps
        thanks you are very helpful
        l mean l want to increase the contrast
        like ricoh or canon
        • mmeldeep
          • Jul 2018
          • 8
          why?
          developer is good
          but I need to increase contrast
          • rockdude
            • Feb 2011
            • 257
            This is why "nomenclature" is 35% of your test score for Xerox and IBM techs.
            The ability to accurately describe a problem is crucial.
            Explanations (and wasted time) by two responders to this post because of improper explanation of the problem.
