CopyCentre C2128 with 10-505.00 and 4-562.00 in need of PWS TOOL.
  • DelawareJim
    • Jan 2008
    • 65
    Hello, I'm a Konica Minolta tech trying to help a small church with a pretty old copier. 10-505.00 and 4-562.00 are showing as faults, also copier is not available and now warming up messages. I can easily replace the ITB but how do reset the code? I think I may need the PWS tool? Not sure, I am out of my wheelhouse on this one. Would appreciate any help. Thanks very much, Jim
  • Mukasa
    • May 2015
    • 178
    Re: CopyCentre C2128 with 10-505.00 and 4-562.00 in need of PWS TOOL.
    Hi
    Can try this if it can help
    The IBT Home Sensor does not detect the Belt Home signal.
    NOTE:
    If this fault is declared 3 times in succession, print mode will be disabled. In order to clear this condition, reset NVM location IOT/Finisher 1221 to 0 in dC131.
    Check the following:
    • If the fault occurs immediately after installation, ensure that the IBT shipping brackets on the left side of the IBT Assembly have been removed.
    • Check that the IBT Belt Cleaner is not damaged, binding, or incorrectly assembled.
    • Ensure that the Transfer Belt is clean, free from damage, and that the Home position reflector is intact.
      (Changed IOT/FINISHER nvm 1221 from 3 to 0.Machine started working)
    • xcopytech
      • Aug 2006
      • 1794
      You can not do anything without pws and diagnostic software for wc2128
