WC7225 in non customer mode + admin login not accepted
  • axyun
    • Aug 2007
    • 1323
    Previously owned WC7225 in non customer mode. Computer unable to recognize machine. Tried login but admin and 1111 not accepted. Don't know user id and password. Any help is appreciated. Frank/AP
  • adriansto
    • 2377
    Re: WC7225 in non customer mode + admin login not accepted
    Two solutions:
    Generate reset code to set the password to default - it need machine serial number and total meter.
    Machine software/ upgrade/reload using altboot.
    • jhalfhide
      • Apr 2015
      • 451
      Non customer mode is solved by changing NVM 616-014 to the value of 2 and rebooting. It will then run through initial setup (language, clock etc...)
      • axyun
        • Aug 2007
        • 1323
        Thank you guys. Much appreciated. To generate reset code would i go into CSE mode. My flashdrive with SM on it is not being recognized bt laptop and need to wait til I get to my desktop computer
        • axyun
          • Aug 2007
          • 1323
          Able to help customer access networking after removing data related to previous owner that prevented customer from gaining access. Machine formerly owned by bank. So now customer is printing and all is well except can't access administrative mode as bank had their own id + password.
          Adi, I wonder ifyou could help me here.
          I would need to change id +password to default or to customer preference. I understand there is a procedure to reset id + password after entering CSE MODE.
          I saw a procedure for the WC5225 but was told that there is a different procedure on the WC7225. Please advise.
          I understand that Xerox can be called and after giving serial# and total they give a ten digit number but would prefer to do it thru UI Diagnostics/CSE MODE
          Thank you for your help Adi + JH
          • adriansto
            • 2377
            I dont know how can that be done from service mode.
            You need the reset code and follow the procedure from edoc for resseting the admin passwd to default.
            • axyun
              • Aug 2007
              • 1323
              Thanks. I saw a procedure for WC5225 nd thought there might be one for WC7225.
              • adriansto
                • 2377
                Nice to have service manual if you fix xerox copiers.
                - machine status button
                - select TOOLS tab then General
                - select Features installation, enter the reset code =12 digits, then OK.
                • axyun
                  • Aug 2007
                  • 1323
                  Thank you Adi. I have SM but did not see this snd the 12 digit code must be gotten from Xerox after submitting serial # + total count.
                  • adriansto
                    • 2377
                    Yes you can obtain the code from xerox customer helpdesk.
                    • axyun
                      • Aug 2007
                      • 1323
                      Customer talked to a Xerox tech and "reinstalled software with altboot" . All is okay now. Thanks for your input, patience and understanding. Frank
