Error 04-563 and 04-561 in Web Display, Machine down
  • wfinn
    • Mar 2011
    • 70
    I have been working on an Altalink C8055 with the errors 04-561 and 04-563. The errors only appear in the web interface and on the display screen it just says: Device not available. System Error: Power off the on. I talked to Xerox who after waiting on hold for an hour and a half had me altboot the latest spar release but that didn't do anything. It was at the end of the day and I didn't have time to wait on hold again. I can't find anything about the 04-561 code and the 04-563 Just says Image Module System Fault and that I had to get from the support.xerox.com page because those don't show up in EDOC. I know this machine had a bumpy ride so I reseated connections I could find on the IOB (I was a Ricoh tech for 11 years so haven't learned the Xerox terms yet), the controller and other boards I saw. pulled components and reseated along with that software update. Im getting ready to spend another hour on the phone but was hoping someone else had seen this.
  • wfinn
    • Mar 2011
    • 70
    Re: Error 04-563 and 04-561 in Web Display, Machine down
    Update on this. After that firmware update and disable data backup during the machine is allowing me into diagnostics which it wasn't allowing before, just rebooting. The image module unit error spelled out in UI was the K LPH.
    • rockdude
      • Feb 2011
      • 257
      Okay so did you replace the Black (K) Laser Print Head (LPH)?
      If so did it fix the problem?
      • XEROX_1111_TEC
        • Aug 2019
        • 68
        I have the same issue. Did the replace of K LPH solved that error?
          • 22808
          we have no idea
          post is over a year old and OP never came back to update us.
          this happens alot... mostly newbie tech/end users are guilty of it.
          • wfinn
            • Mar 2011
            • 70
            we have no idea
            Actually I completely forgot all about this problem until I just had it happen again today and did a search for the error. The print head did resolve the issue.
