Xerox Color 1000 Press fault 045-379
  • kellyjmk
    • Aug 2015
    • 14
    After installation and PO, the Xerox Color 1000 Press idled for approx. 5 min, then fault code 045-379 popped up on the screen.
    The manual listed a "Burned-out fuse on the Drive Mother Board" as a Recommended solution. Anyone seen this fault who can explain it in plain English ? Would like to get it running before putting it on service.
    TIA
  • adriansto
    • 2388
    Re: Xerox Color 1000 Press fault 045-379
    The problem is somewhere in fuser zone, fuser assy, cooling belt, fuser drawer intrelocks, pressure roll cam, exit drawer interlocks 24 volts presences.
    Check that zone. If you want to selfservice this machine the very good ideea is to have service manual.
    • kellyjmk
      • Aug 2015
      • 14
      adriansto
      Thanks for the reply. my selfservice is only to get it running, then it goes on service. Haven't been able to find a manual on google. seems I need to get acquainted with the fuser area.
      Thanks again
