Customer sent me fault history from control panel. Does the fault history go to last 20 or is it more than that?
From what the customer sent there are 20 codes with repetitions of same codes which seem to have started on Oct 14,2018. Below is the list in order of sequence
This is all listed with the oldest codes first in order to understand the origin of problem
# Fault Code Date Time Image Count
20. 303.777.00 2018-10-14 11:55:32 AM 0
19. 303.777.00 2018-10-14 03:30:14 PM 0
18. 303.332.00 2018-10-14 03:35:16 PM 20,261
17. 303.777.00 2018-10-14 03:39:41 0
16. 303.777.00 2018-10-14 05:19:50 PM 0
15. 303.332.00 2018-10-14 05:24:55 PM 20,261
14. 303.346.00 2018-10-14 05:33:13 PM 20,261
13. 303.777.00 2018-10-19 04:50:56 AM 0
12. 303.777.00 2018-10-19 07:45:00 PM 0
11. 389.603.00 2018-10-20 01:03:42 AM 20,270
10. 303.777.00 2018-10-20 11:09:06 AM 0
9. 303.777.00 2018-10-20 03:01:31 PM 0
8. 303.777.00 2018-10-20 08:37:55 PM 0
7. 303.777.00 2018-10-20 09:52:11 PM 0
6. 303.777.00 2018-10-21 04:04:52 PM 0
5. 303.332.00 2018-10-21 04:09:55 AM 20,276
4. 303.346.00 2018-10-21 04:18:25 AM 20,276
3. 303.332.00 2018-10-21 09:38:32 AM 20,276
2. 303.347.00 2018-10-21 09:42:12 AM 20,276
1. 303.777.00 2018-10-21 09:45:00 AM 0
The Background of this is that I sold the customer a lease end WC7225 with low volume (19,900) . The machine was copying and customer was able to print using usb but not network. This was due to previous owner ( a bank) having certain security in place which an IT guy had helped customer to resolve. Also he bank had
their own ID + passcode for administrative access. This the customer called Xerox and a Xerox rep helped customer over phone to altboot and gain access to administrative mode in order to configure machine to customer's preferences. this was around October 4, 2018.
At the time the only issues appeared to be IT related and not a machanical functional issue. I am afraid customer will try to get money back when he has been
doing it another stuff with the help of 3rd party. I was not even made aware of these fault codes which started on Oct 14 until today. Customer said he was away and came back on Oct 18 and saw fault codes but obviously someone had to be there to turn machine on and off and this is not in an office but at customers apartment(home) where only he uses machine and maybe perhaps, his wife.
Any help and iformation you can give would be most appreciated. Most of the codes appear to be repetitions but one code stands out, the 380-603.00.
I am not at my home computer but on a laptop without access to the SM I have. My flash drive, which i have is unable to be detected at this time for some reason. I will try to get what I can online in meantime. Frank
