Workcentre 7225 Cleared print jobs on machine then keeps showing back up.....
  • Doug James
    • Jan 2012
    • 935
    [Misc] Workcentre 7225 Cleared print jobs on machine then keeps showing back up.....
    Weird problem. The customer says that when they clear the print jobs from the machine the print jobs keep re-appearing. (It's an Air Force Base). They said it successfully clears initially. They say there is nothing on the server being print to it. Any help would be appreciated...
    Re: Workcentre 7225 Cleared print jobs on machine then keeps showing back up.....
    seeing how it is a military base... and knowing how redundant the GOV is.. I would suspect they haven't properly cleared the que.. but they will NOT let you go digging around in the server.
    • Doug James
      • Jan 2012
      • 935
      He said he was able to install a SPAR firmware from general release firmware and got it working that way... I am also thinking that the que wasn't cleared. Thanks so much for your response !!! Really appreciate ya !!
        i used to work @ Ft Bragg and LeJune .. some of those huys don't know their ASS from the potholes in the roads
