versant 80 banding
+ More Options
Posts
  • apcrap
    • Jun 2010
    • 25
    versant 80 banding
    Have a v80 with a banding issue 70mm from the trail edge that doesnt move only running black . All drums , dv units , 2nd btr assy , transfer belt , cleaning unit , 1st btrs with holders , upper fuser belt and pressure roller . This is a print shop running 13x19 14pt and 12x18 100lb coated stocks . I just swapped out drum drive units there was no change . The single colors c,m,y look fine running 325 test print . The machine has tag 13 .
  • InterfaceP
    • Jun 2013
    • 488
    Re: versant 80 banding
    Is it configured with the Tag 13 Flywheel?
    • apcrap
      • Jun 2010
      • 25
      Its all fixed the the hvt in the transfer unit fixed the problem
