Docucolor 700 with error 010-326
  • axyun
    • Aug 2007
    • 1323
    Docucolor 700 with 010-326 fault. Wiil check fuser. Can someone please give me which nvm value to set to 0. I know for 010-319 and 042-326 but not this. Frank
  • axyun
    • Aug 2007
    • 1323
    Re: Docucolor 700 with error 010-326
    Was able to purchase sm today and that unlike 010-319 and some other fault codes there is no nvm value reset for the 010-326 fault. Going on call
    tomorrom morning and wil check out fuser unit for thermistor etc issues.
    • axyun
      • Aug 2007
      • 1323
      When I arrived at machine there was a fault code 010-119. I reset the value to 0 on the specified nvm address . When I turned on machine got 010-326
      Customerhad couple of good fuser units. I swapped fuser but did not alleviate problem. Someone said it was likely power sepply but i will investigate further. Frank
