XEROX WC5330
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Error Code] XEROX WC5330
    Hello everyone we have error code 061-320 . xerox wc5330 ..pls any idea ?
    BEST TECHNICIAN . NICE PEOPLE .
  • Mukasa
    • May 2015
    • 178
    Re: XEROX WC5330
    Hello Zaza ,
    When does this code come on , when warming up or when you press start to print.
    These fault code is about the ROS Motor.
    • The ROS Motor rotation speed does not reach the specified value within the specified time after the ROS Motor started rotating.
    • The light intensity of the LD1 does not reach the specified value.
    Procedure
    Check the connections of P/J406 on the MCU PWB and P/J140 on the ROS Unit.
    Connections are connected correctly. Yes No Unanswered
    Connect P/J406 and P/J140.
    Check the connections of P/J160 and P/J170.
    P/J160 and P/J170 are connected correctly.Yes No Unanswered
    Connect P/J160 and P/J170.
    Check the wire between J406 and J140 for an open circuit or a short circuit (BSD 6.4 Flag 1/ Flag 2).
    The wire between J406 and J140 is conducting without an open circuit or a short circuit. Yes No Unanswered
    Repair the open circuit or short circuit.
    Check the wire between J406 and J130 for an open circuit or a short circuit (BSD 6.5 Flag 1).
    The wire between J406 and J130 is conducting without an open circuit or a short circuit. Yes No Unanswered
    Execute Component Control[061-200 ROS MOTOR ON].
    The ROS Motor can be heard. Yes No Unanswered
    Measure the voltage between the MCU PWB P406-10 (+) and GND (-) (BSD 6.5 Flag 2).
    The voltage is +24VDC. Yes No Unanswered
    Measure the voltage between the MCU PWB P400-1 (+) and GND (-) (BSD 1.2 Flag 1).
    Measure the voltage between the Power Unit P526-4 (+) and GND (-) (BSD 1.2 Flag 1).
    Replace the Power Unit ( PL 9.1).
    Repair the open circuit between J526 and J400.
    Replace the MCU PWB ( PL 9.1).
    Replace the ROS Unit ( PL 3.1) If the problem persists, replace the MCU PWB ( PL 9.1).
    Install the Xero/Developer Cartridge securely.
    Measure the voltage between the MCU PWB P406-2 (+) and GND (-) (BSD 6.4 Flag 3).
    The voltage is +5VDC. Yes No Unanswered
