xerox 260 fiery bustled bustled
  • Mukasa
    • May 2015
    • 178
    Hi
    Xerox 260 fiery bustled bustled is very stubborn it works for two days then it fails to connect , it looses network .
    For the last one month i have installed software four (4) times. I have even put a new HDD but still did the same, what might have gone wrong inside the fiery.
    Godfrey
    Re: xerox 260 fiery bustled bustled
    Originally posted by Mukasa
    Hi
    Godfrey
    well with what lil information you have provided the "busted" part could be anything from network settings ( never mentioned HOW it is connected ) to a bad port on the fiery ( no mention of testing it ) to a bad cable ( did you try a new one ) or even VIBRATION on the floor...
    why did you waste all that time re-re-re-loading software? after 1st time you should have diagnosed the issue further ( really should have been the STARTING point!!!! )
    • Mukasa
      • May 2015
      • 178
      Thanks bro,
      the cables are fine because after installing the software the machine connects and start printing normally , but after three to five days it looses the connectivity . what i do is to re-install the software to work again for a few days.
        Thanks bro,
        sounds more like a NETWORK problem... but here again you give VERY little information to work with.
        • adriansto
          • 2387
          Thanks bro,
          Try to reinstall on new hdd
            according to his 1st post he did that already.
